Question about running 10 mm and 15 mm spacers???
I'm currently running 10mm spacers in the rear on my gs300. I want to exchange them out for 15 mm spacers on my existing studs.
The studs currently fits the 10mm perfectly, if I was going to use a 15mm spacer, the studs will not clear the additional 5mm.
Doesn't sound like it works, but I called Ichiba and they said that the 10mm and 15mm spacers uses the same size studs.
So, can I safely use the 15mm spacers even though the studs are 5 mm too short?
Thanks for the help!
