Road Force Balance
Road Force Balance
my LS460 had a rough ride prior to the dealership performing a "road force balance". Since my tires needed this extra service...will this be something that will have to be done again as the tires wear down? Or is it a "do it once and forget it" thing?
exclusive matchup
wheel balance can be off even during the lifetime of the tires themselves. however, i wouldn't say if there is a MUST period between each balancing. usually you tell by tire wear, ride, and also vibrations.
road force balancing applied road force on the tires as well (i believe) when you balance the tires, creating better and closer to reality results when balancing tires. i am not 100%, but i believe only higher end hunter machines can do it?
Here's some info on road force balancing
http://www.hunter.com/pub/product/ba...159T/index.htm
They say:
Solves Vibration Problems Balancers Won’t Fix
- Detects non-balance, radial force-related problems associated with: Tire uniformity.
- Tire and rim runout.
- Wheel-to-balancer mounting error.
- Improper bead seating of tire to rim.
Faster Troubleshooting & Repair
- Quickly calculates the contributions of the rim and tire to radial vibration problems and presents the technician with easy step-by-step repair instructions.
They say:
It works!
I have used the 'Road Force' balance on two different cars and have been very happy with the results. In both cases one tire/wheel was the problem. The tire was demounted, rotated to the position that the machine recommended, remounted and the vibration was gone. It is one amazing machine !
Of course, no machine can match the results from the good old "bubble" balancing we did 40+ years ago (just kidding).
mattds
ES - 5th Gen (2007-2012)
07-21-13 06:28 PM
