Tire Size
In order to maintain the overall correct diameter of your tire, the higher the aspect ratio(55 to 60) you need to have narrower(225 to 205) width, otherwise you will have incorrect speed because you tire is either bigger(faster speed) or smaller(slower speed).
Here http://www.discounttire.com/dtcs/infoTireMath.dos , you can do the calculation yourself. Hope it helps...
The aspect ratio (series) is the percentage of the width of the tire that exists as sidewall. In other words, the 225/55 stock tire is 225mm wide and has a sidewall height of [225*.55]mm. The 60 series will have a sidewall height of [225*.60]mm. Notice these two quantities are about equal [225*.55]~[205*.60].
That being said, you are getting the same sidewall depth cushioning the ride whether you are 225/55, 205/60, or 245/50. Yes, the 205/60 will be marginally more cushiony; but, there are other variables to consider: traction, looks, load rating, etc. The narrower tire will make the car look like it is on four spare tires, and the narrower tires are built to handle less load.
A properly picked new OEM-sized tire will greatly improve the ride quality. Some tire types run smoother or quieter, and new tires ride smoother than those with low tread for sure.
All things considered, I would stick to the OEM 225/55. I would simply seek out a high quality passenger tire that will keep the ride smooth and road noise to a minimum. The 205 will not only not look ride, but it will throw other variables out of balance as well.
This advice is proper in that the 205/60 will most closely maintain the stock running diameter of the 225/55. The 225/60 will run tall. Messing with the tire diameter will make your speedometer and odometer monitor speeds and distances incorrectly. Whatever tire you choose, maintaining the stock running diameter is critical.
A properly picked new OEM-sized tire will greatly improve the ride quality. Some tire types run smoother or , and new tires ride smoother than those with low tread for sure.
I am very sorry for that. Well i'm running stock 16" with Dunlop Sp Sport A2 225/55/16 and my last set up was Dunlop as well. I am looking to get some all season tires. I just want something quiet smooth confortable dunlop just not doing it for me anymore
yESman
Wheels, Tires & Brakes Forum
12-05-06 12:50 PM
