replacing fronts and not rears?
I need to replace my rear tires, but after examining the fronts, i am certain i can get another 10,000 miles out of the fronts.
Is there anything wrong with just replacing the rears? Another thing, they don't make bridgestone SO-3's anymore so my tires will be mismatched if i just replace the rears. My options are:
1.) I'm thinking of getting Bridgestone RE050A rears to go with my Bridgestone SO-3's in the front.
or
2.) Getting a set of Goodyear Eagle F1 GS-D3 front and rear.
I think i know what you guys are going to recommend, but i would rather spend 500 than 1000 on tires.
Thanks!
or
Thanks!
Maintenance Moderator
Now, every major tire manufacturer, RMA, and more (even Top Gear) recommends putting newer, better tires on the rear of a vehicle...
reasoning - it is easier to control a blow out on the front, and, more importantly, it is easier to control a car that is understeering rather than oversteering... (the same reason manufacturers build understeer into every production car made - well, almost every)
they also recommend higher speed rating (if theres a difference) be mounted on the rear as well...
I forgot to mention that i have a staggered wheel setup, so i can't swap the fronts to the rears. It's either buy 2 rears or buy a whole set of tires. I'm leaning towards buying the rears and see how they feel. If it feels weird, i'll just order the fronts immediately.
If you are pretty positive you can get 10,000 miles more out of the fronts, then I would just change out the rears. You paid good money for the fronts and should run them until they are bald. I would understand why you would even want to swap the whole set at once when you're fronts still have meat left on them-- to save you a trip to the tire shop.
I am 85% sure i can get another 10,000 miles out of the fronts. Another thing about my car, i only drive it 2 or 3 times a week. So 10,000 miles is about 1 and a half years before i will need to replace the fronts.
I just ordered the rears and hopefully i won't have any ride issues with the mismatch.
Thanks for everyones input.
1 1/2 more years? I would say hold off on the fronts then. I have Hankooks in front and Falkens in the rear and there are no issues for me. I wanted to get matching Falkens in for the fronts but the Hankooks had a treadwear rating of 420 and I got them for a very good price. My driving style is conservative and although the Hankooks are rated at only A traction and not AA like the rears, I have not noticed any difference in performance because of my conservative driving. The only complaint I have is the front tires seem to produce a lot more road noise than the rears.
BlueCrabby
Wheels, Tires & Brakes Forum
10-29-11 08:00 PM
