Blizzak LM-25 Snow Tires...H or V Rated?
Old 11-02-06, 07:50 PM
Tranman
Registered User
Tranman's Avatar
Default Blizzak LM-25 Snow Tires...H or V Rated?
Well, it's that time of year again..to worry about snow. And my old LM-22's are worn down now, so I am looking at the newer LM-25's. However, I noticed that there is an H-rated and V-rated version of it. I was wondering if anyone had any input. I suppose that the H-rated rides a bit softer than the V? There is about a $10-15 difference.
Old 11-05-06, 05:45 PM
kaslead
kaslead's Avatar
I'm curious about this also. If the load ratings on both Blizzaks at least meet the OEM ones, then I think it should be ok. H speed rating should be more than sufficient, right?
Old 11-06-06, 08:25 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
either will work, typically, in a snow tire, the lesser speed rating, the better snow performance... downfall, obviously, is a lower top speed of the tire...
get the lowest you feel comfortable with, and that you won't exceed...
it's accepted that you can drop 1 speed rating when using snow tires...
car came with Z, V is ok, car came with V, H is ok (however, personally, if a car has a performance rated tire, anything over H, I would never drop below H)
Magellan55
HS 250h Model (2010-2012)
12-08-10 03:11 PM
17gs400
04-10-10 10:56 PM
Adrian350
10-17-07 10:16 AM
IAGS400
12-12-05 12:55 AM
Quick Reply: Blizzak LM-25 Snow Tires...H or V Rated?
