View Poll Results: Stretched tires, should I go wider or narrower?
Change the front to 235/35/19
45.45%
Change the rear to 285/30/19
36.36%
Keep them the way it is.
18.18%
Voters: 11. You may not vote on this poll
Stretched tires...
Old 03-09-06, 10:51 AM
gapxguy
gapxguy's Avatar
Default Stretched tires...
I'm currently running 19's 9F and 10R. 245/35/19 F and 275/30/19 R. Since the rear is 10" wide, the tires really stretched - almost riding on the side wall (looks really nice though). The front too, but not as bad. So I question if my rims are more prone to get damaged from the lip being more exposed?
I'm at the lowest position in the front with my Tein CS, and at heavy dips it scrapes the fenders.
Should I change the front to 235/35/19 or change the rear to 285/30/19?
Old 03-09-06, 01:00 PM
AZDesertGS
AZDesertGS's Avatar
I would say change to a 235/35....since that would be the correct diameter tire to go with the 275/30. Also you might not rub then.
Old 03-09-06, 01:35 PM
onihc
I heart Honda
onihc's Avatar
what tires are you running? i use Bridgestones and the rears are slightly stretched. i run 235 on 9 inches, now that is stretched, but within manufacturer's specs. looking at my ruler, 245 on 9's stretches more than 275 on tens.
with 235's i have to baby my wheels, and i check the pressure every week. i have my fronts running 35 psi.
Old 03-09-06, 02:17 PM
rominl
exclusive matchup
rominl's Avatar
by exposing more of the lip of course it's easier to damage the wheels,that's a given
if you change to 235 in the front, stay with 275 in the rear.
Old 03-09-06, 06:49 PM
AME_VIP
AME_VIP's Avatar
19x9 and 19x10 I run 225 and 245 to provide better clearance. No problems.
Honestly, when I'm running high dollar wheels I am extremely careful not to curb my wheels whether I am stretching or not.
Old 03-09-06, 06:54 PM
VipDout
19x11.5 -51
VipDout's Avatar
Hmm i have 19*8 and 19*10 ...i am going to stretch the tires next time around so i can go lower... and not rub...
be Nice to see your current set up ... post a picture
i have 275/30/19 on the rear and i might go 255 in the read ... better look for me cuz i like to slam my car .....
Old 03-09-06, 09:16 PM
gapxguy
gapxguy's Avatar
Wow! Pics? I thought I my tires were stretched.
Here's my setup...
Looks like I'll go 235/35/19 in the front since being that stretched is normal, and it'll be nice not to rub anymore.
Old 03-10-06, 04:16 PM
onihc
I heart Honda
onihc's Avatar
now this is stretching tires. check it out. https://www.clublexus.com/forums/sho...d.php?t=149711
Old 03-10-06, 04:37 PM
sockfocks
sockfocks's Avatar
slightly off topic but back in the day I had 15x8.5 with 195/50's on my 81 cutlass...hehe....
Old 03-10-06, 04:49 PM
onihc
I heart Honda
onihc's Avatar
was it lowrider?
Old 03-10-06, 04:53 PM
sockfocks
sockfocks's Avatar
well i had V-6 springs in front with a V-8 engine....so it had a lil rake to it...it wasnt slammed but it did look good on 5 star Prime machined centers with polished lips....I was still in high school, man that car was fun
Old 03-11-06, 08:19 PM
SSK0771
SSK0771's Avatar
I would go with 245-35-19 and go with 285-30-19 for the rear.
Also as for streched look, it also has to do with type/brand of tire you have. Bridgestone S-03 and Dunlope Sport Maxx have strong/thick side wall so even with 245's on on 9 inch width rim, it does not look stretched but if you go with Toyo's or Falken, it will look stretched. Different tires have look different even with sames size wheel.
Old 03-11-06, 08:25 PM
gapxguy
gapxguy's Avatar
Tires are Dunlop SP9000. I'll most likely replace the front tires with 235/35 to eliminate the rubbing issue.
Old 03-11-06, 09:39 PM
SSK0771
SSK0771's Avatar
That will have streched look. I personally like little streched looked but not too much.
Old 03-12-06, 10:41 PM
D2-AUTOSPORT
Former Sponsor
D2-AUTOSPORT's Avatar
Off topic the wheels look GREAT.
Quick Reply: Stretched tires...
