Question on backspacing and offsets
i found a set of used ccw i want to get but the seller doesn't know the offsets. is it possible to find out the equivalent offsets from backspacing measurements:
6.25" backspacing on 18x9.5
and
6.75" backspacing on 18x11
someone please help me out. thanks
and
backspacing is the measurement from the plane of the rear lip to the plane of the wheel hub. within this measurement is the offset. offset is the measurement from the plane of the CENTERLINE to the plane of the wheel hub. so subtract half of the rim width from the backspacing value and then multiply by 25.4mm.
18x9.5: 6.25 - 4.75 = 1.5 ~> 38.1mm offset
18x11: 6.75 - 5.5 = 1.25 ~> 31.75mm offset
what do you (or anyone) think about this set up on a stock sc400? will i need some serious fenders rolling on the rear? thanks
5sp is on the right track, but the offsets are wrong!
People forget that a 9.5" wheel is really 10.5" wide. The wheel width dimension does not include the inner & outer bead seat thickness, which is 1/2" per bead. Hopefully, you considered this when measuring the car for wheels!!!!!!!!!
18x9.5 = 10.5" overall. The centerline of a 10.5" wide wheel is 5.25"
Your desired backspacing is 6.25", leaving a difference of 1.0"
Multiply 1.0" x 25.4 to convert to millimeters
18x9.5 +25.4mm
18x11.0 = 12.0" overall. The centerline of a 12.0" wide wheel is 6.0"
Your desired backspacing is 6.75", leaving a difference of .75"
Multiply .75" x 25.4 to comvert to millimeters....
18x11.0 +19.05mm
I hope it's not too late to fix your wheel order... otherwise, you'll be in the market for some spacers...
18x9.5 +25.4mm
18x11.0 +19.05mm
if that's the way it works then i didn't know but...that's confusing as the widths should have been stated as 1" wider. rather than guesstimate, check for the offset if you can. good luck with the search!
Also, the actual wheel diameter is larger than the stated size... again, the tire manufacturers are concerned with the diameter of the bead-seat area- a 19" tire has to fit a 19" wheel, and so-on. But you need a flange to locate ot 'hold' the tire on the wheel. A 19" wheel (for example) really measures about 20.5" outside-to-outside.
You measure a wheel diameter & width in inches, backspacing in inches, offset in millimeters, tire diameter in inches, tire width in millimeters, and sidewall height is a ratio. Clear as mud, right?
If it wasn't confusing, I wouldn't have a job!!!!!!
