Tire brands for front and back
On my GS300 I was advised to get the following tire setup:
245/35/20 - Front
275/30/20 - Rear
Can I get different tire brands for the front and back or does it have to be the same brand? What are the consequences of have front and rear different brands? Thx.
245/35/20 - Front
275/30/20 - Rear
Differnt brand means that the tires will be maade of different materials. This usually results in a difference in traction. Rear tires gripping while front are sliding thru a turn....or the other way around. Temperature also has a great deal to do with how well the tire holds on the road. On a cold day you might have less traction with one set over the other. Thats the only real important difference I can think of. Just make sure you get tires with the same speed rating all the way around. You dont want to go 140 and have the front tires blow out on you.....that could be bad.
I suppose you could also say the wider tires in the back are likely to hold longer than the slimmer fronts. Having different tires is not so different from that. Again, the issue only arrives at the limits, so as IS_250 says, unless you're on the track it shouldn't matter.
radicalrev
Wheels, Tires & Brakes Forum
04-16-08 05:57 PM
