question on lug nuts
for those running a staggered setup with big brake clearence on the front wheels.
it seem that you would need a larger lenght lug for the front and a regular lenth on the rear.
if this is true, how do you get lock lugs? do you have to buy two different sets to accomendate the two different lug lenghts?
any one suggest some good locks 12mm x 1.5 acorn.
backs seems to be about 1" long
the front would need about 1.5" long.
no
get 12x1.5 et shank lug kit,,,,,,,,,,any place that sales rims in your area should have them should come with 20 lug nuts, 4 locks, 4 valve stems, and should be 30-40 bucks,,,,,,,,,,,,the et shank will go into the lug hole of your rim and get you extra turns if length is a concern,,,,,also it will help in centering the wheel......hub centric rings or wheels are still the best centering though,,,,,,,,,but every little bit helps
later,
mike
later,
mike
