Cross-Drilled/Slotted Rotor for LS430?
Does anyone here have some info about replace the OEM rotors with some cross-drilles/slotted rotors?
I saw a set of four Brembo rotors on eBay but didn't wanna get screw for buying some cheap stuff (like most of people with eBay.)
Originally posted by rominl
no idea at all, but maybe you should check with steve ganz?
if i reember right, the size is a TAD smaller than supra
I just want to paint or powdercoat the OEM calipers, then put on some cross-drilled/slotted rotors. Don't wanna spend for a Supra TT brake setup. Plus, Supra TT has slotted only rotors......IMO, not flashy enough
exclusive matchup
well honestly i don't see why you would wanna go to supra tt brakes when it's only maybe 1 to 2mm bigger in rotor size. both of them are 4 pots, and the ls430 caliper is full aluminum monoblock, a lot lighter than the supra tt unit. i only see pluses with the ls430 setup
I'm assuming the front may be bigger but found a cool deal on rear rotors pads slotted/drilled
http://www.buyautoparts.com/plabuyno...LtXBoCgq3w_wcB
outlaw0209
SC- 1st Gen (1992-2000)
01-13-10 06:58 PM
