rubbing with 19's
rubbing with 19's
hey guys i have a problem, i just put on a set 19's axis mods on my 02 IS .the front are 19x8 and the rears have the offset 19x9's , I can't have any one set in the back of the car cause that will cause it to rub when the car is moving and hits a dip along the road. The car is not dropped at all and it looks like the part thats rubbing is the very edge of the outside of the tire with the inside edge of the quarter panel at the very top. I was thinking that i might have to grind down that insisde edge of the quarter panel and maybe it will give the clearence i would need, but if u guys have any better suggestions please let me know thanks.
Shave or roll.....
Shaving is one option but take it from an experienced bodyman, you'd better know what you are doing otherwise you run the risk of effecting the fenders structural integrity. Those lips are there for a reason after all.
Fender rolling is the other option.....
https://www.clublexus.com/forums/sho...hreadid=134406
thanks guys for all the suggestions I brought my car into super autobacs and they were able to the grind and sand down the inside lip of the fender with no problems to the fender, hopefully that will be the end of this problem
rfx45
05-22-08 08:39 PM
Seize
Wheels, Tires & Brakes Forum
12
04-11-05 09:36 PM
