Correct psi per tire? (19)
exclusive matchup
Originally posted by SexySC
I keep them at 35 (cold) for both my Lexus and Infiniti, they'll be at ~38 after running for a while, is that not safe enough ? Roads here are generally quite good, and I'm fortunate enough not to have ever bent a rim yet.
and LexAristo, it's not about safe or not, all it takes is a pothole out of nowhere
My tire shop recommended 45-48 psi, but that way it felt like I had no tires at all... now I have 42 psi all around, the rides much better and still (thank God) no problem with tires bubbling nor bent rims. I believe with lower profile tires (30, 35) you should have at least 40 psi... safer for your rims, especially when you're hitting potholes since you have more "air cushion" within the tires.
is250tx
Wheels, Tires & Brakes Forum
01-12-10 05:54 PM
audphile1
10-08-04 08:25 AM
