Are iForged wheels hubcentric?
Originally posted by Letsride
I thought they were lug centric!
exclusive matchup
hub centric means that the wheel are center by the hub. if you take your wheels out you will see that the hub comes out a bit, where the rim rests on
lug centric means that you need to "center" the wheel using the lug nuts, tighten them to push/pull the wheels to be centered
in most cases the lug centric wheels will have slight vibrations at speed. nothing wrong, just the characteristics. my old volks were lug centric, had that little vibration at 60mph. my new hre, no problem at all.
i am not sure if iforged are hub or lug centric though. would be pretty surprising if they are not hub centric coz' you are customizing a wheel already
