Broke lug nut stud
Broke lug nut stud
Rotated the tires yesterday and broke a stud on my 2002 IS300
Lexus quotes me a minimum of $300 (3 hours), this seems outrageous to me but does anyone have any experience getting one fixed? I'm going to take it to a tire shop first, see what they say.
Yeah, shouldn't be hard to do. Unless there's something unique about the IS setup, the dealer is trying to bend you over. The stud itself shouldn't cost more than $2 or $3 at a parts store like NAPA. If you've got the tools, remove the wheel and rotor; then knock the broken stud out with a big hammer. Put the new stud in and use a lugnut to fully tighten it into place. It's definitely not a $300 job, so do it yourself or find somewhere else.
Wow, $3 for a part and $297 for labor..That is just outrageous.
Seriously, like Kyle said, it's very easy to do if you know how to remove your brake pads and rotors.
Ed
Ed
Man take it to a Belle Tire (if you have one near you) and they will fix it for free probaly. When I was in High School I worked at a Belle Tire and fixed broken studs in about 2min.
SCRUFF and Din - how did ya break them!?!!?
so remeber guys if u haVe hub rings to remember to remove them if u put on ur spares .
Originally posted by Din
i had got a flat tire on my rim, when i put the spare on i forgot to remove the hub centric ring so when i was drving the spare was wobble wobble stressed out the lugs, when i went to takethem off they broke off.
Factory spec is 76 lb/ft I believe, which is what I use.
