Suspension Springs, shocks, coilovers, sways, braces, etc.
19" Wheels with a 40 Offset?
Old Jun 7, 2021 | 05:21 PM
jgscott's Avatar
jgscott
Default 19" Wheels with a 40 Offset?
Hi. How would a 19" wheel with a 40 offset work on the GS350?
I think the stock F Sport 19" wheel is 45 offset correct? So would a 40 offset be ok without a Spacer or anything? Would that place the wheels inward some or outward winder stance? I am not a wheel guy so thanks for all's help.
Old Jun 7, 2021 | 07:21 PM
gdog5149's Avatar
gdog5149
Scott,
My car is set up close to those specs if you care to look at my pics.
G
Old Jun 7, 2021 | 09:46 PM
jgscott's Avatar
jgscott
Originally Posted by gdog5149
Scott,
G
Yes I would. Can you post some pics please. Thanks.
Old Jun 8, 2021 | 06:04 AM
TarmacSL3's Avatar
TarmacSL3
Correct the stock F Sport Fronts are +45, so yes a +40 offset would work but that all depends on if you are staying with the 19x8 OEM wheel. If you going aftermarket then the face design also come into play. For instance my aftermarket fronts (Semi Concave) are 19x8.5 +30, which puts the wheel flush with the fenders and clears the large front calipers, I probably could have gotten away with a +35 and still clear.
Old Jun 8, 2021 | 06:36 AM
jgscott's Avatar
jgscott
Looking at staying with a Stock Spoke type wheel. So would 40 pull the wheels in tighter a bit? Or out wider apart? Thanks.
Old Jun 8, 2021 | 08:29 AM
TarmacSL3's Avatar
TarmacSL3
It will push the wheels out 5mm so closer to lining up with the fender. You should have no issues.
Old Jun 8, 2021 | 08:48 AM
jgscott's Avatar
jgscott
So away from the caliper out spread a little wider wheel base right? Thanks.
Old Jun 8, 2021 | 09:46 AM
jgscott's Avatar
jgscott
Hey another question as I search. The 2013 - 2015 F Sport 19" wheels? On the RWD they are staggered at 19 x 8 front and 19 x 10 rear correct?
So does the AWD F Sport have a "19 Factory Rims the same width all the way around? Like 19 x 8.5 front and rear? Thanks.
Old Jun 8, 2021 | 10:56 AM
TarmacSL3's Avatar
TarmacSL3
Yes away from the caliper so a wider track.
Yes AWD has the same width front and back
F Sport RWD are 19x8 +45 Front and 19x9 +60 Rear
F Sport AWD are 19x8 +45 all 4 corners
Old Jun 8, 2021 | 11:02 AM
jgscott's Avatar
jgscott
Ok Thanks. Is the AWD 8.5"s Width all around? Anyone know?
Old Jun 8, 2021 | 11:21 AM
TarmacSL3's Avatar
TarmacSL3
AWD is 19x8 all around not 8.5
Old Jun 8, 2021 | 12:07 PM
jgscott's Avatar
jgscott
Ok got it. Now I know what to look for. I don't want to deal with the Limited tire selection of the staggered set up.
So now I'm looking for a set of GS F Sport 19" stock wheels to buy new or preferably Take off Used wheels. Thanks. Every time I searched I found all kinds of non specific to the type car and width info. Now I know what to get. Thanks.
So the AWD F Sport 19" is 45 offset 8 inch wide rim all front and back? Correct. Thanks all!
Old Jun 8, 2021 | 12:59 PM
gdog5149's Avatar
gdog5149
They are posted under my profile........https://www.clublexus.com/g/user/350405/photos
G
Old Jul 5, 2021 | 04:53 PM
jgscott's Avatar
jgscott
G
Thanks, for the link too.
Old Jul 5, 2021 | 04:57 PM
jgscott's Avatar
jgscott
So I think I found a set of GS350 F Sport RWD Staggered rims at 19x8 front and 19x9 rear.
Can I run all the tires the same size say 245-40-19 all front and rear? I noticed the offset was 60 on the rear. Would having all the same tire sizes cause a issue?
