Eibach or tanabe springs?
Need your opinions? I am putting on my 20" Maya rims this weekend. 20x10 with 43 offset/ 275-30-20 and 20x9 (not sure of offset) with 245-35-20.
I am planning on lowering it with springs the same time i mount on the wheels. Any suggestions or opinions on which springs i should use? I see that most are using Tanabe, but i heard Eibach are also good? Also, am i purchasing the correct tire size? I am going for a clean and stock ride. Thanks, |
how low do you want to go? if you want just a mild drop like me, then tanabe nf210 should fit the bill. any lower, i would recommend getting coilovers; the ride can get fairly stiff (ie: harsh) when you go with springs that are lower than the nf210.
Maybe an inch or two gap. I'm more concerned about a fender rub and smooth ride then how low the drop is. I initially wanted coil overs, but will settle for springs.
Do you think 245-35-20 will rub up front? |
Originally Posted by aces wild
(Post 4662192)
Do you think 245-35-20 will rub up front? http://www.wheelsmaster.com/rt_specs.jsp |
1. Moved to suspension forum
2. Please search. Tons of info and pics posted to help you. |
