Camber Kit R&D:Revenge Motorsports (ElCajon,Ca)
#91
executive matchup
I'm running Megan rear camber kit, upper and lower traction arm, toe arm and camber arms. Had I known about Figs engineering before I got mine, I would have gone with that, as a friend of my has it and the engineering and Craftsmanship is top notch.
For the front, I'm running SPC front camber fitted for an IS300. Some members said that it requires sanding down the upper control arms. I didn't sand or grind anything. I'm AWD. Hope this helps.
