ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   Suspension (https://www.clublexus.com/forums/suspension-214/)
-   -   alignment after tanabe nf210's (https://www.clublexus.com/forums/suspension/185476-alignment-after-tanabe-nf210s.html)
rdwatson Nov 1, 2005 12:19 PM
just got the tanabe nf210's installed. Looks great but dealer says you can only adjust toe in on the alignment, NOT camber/caster :sad: Is this right?
LEXISM Nov 1, 2005 12:35 PM
I beleive that happends w/ many makes when lowered ....you can only adjust the toe not camber ....that is why a camber kit is needed
foofighter Nov 1, 2005 12:52 PM
you are correct...the new GS they did away w/ even the front end's camber adjustments so you're basically stuck w/ it. Some may argue but Toe is equally important to the tire's wear...so set the toe and drive it.
