99 sc400 rear tow arms
in search of a few recommendation for rear tow arms for my mostly stock 99 sc400
having stabilty issues in the rear |
Just out of curiosity, have you tried a good alignment? I've had my rear subframe thrown out of wack slightly after a hard track day and had to hit the alignment rack to get everything square again.
Going to get the rear aligned first to check
thanks Rudy |
It'll be worth a shot - have them check your bushings for play while they're at it to be sure everything is solid.
Originally Posted by Vitamin-SC
(Post 10434612)
having stabilty issues in the rear EDIT: Usually what goes in the toe arm is the tiny ball joint in the inboard end so there is no repair/rebush of that. If there is slack, and usually this is the first place it shows up, you should replace the toe arm before spending money on an alignment. There are also aftermarket options out there that isn't much more than the stock ones from amayama once you add shipping. https://cimg1.ibsrv.net/gimg/www.clu...c03c7ab160.png |
