Lexus brake pad & rotor part number?
Hey all,
Quick question
What is the correct pad & rotor part number for an 2015 IS250 F-Sport RWD?
mylparts.com said for my right and left rotor: 43512-22260 & 43516-22010
pads: 04465-30480
Just double checking. I plugged in my VIN on lexuspartsnow.com and looked up the rotors, website said the rotors didn't fit my car.
Quick question
pads: 04465-30480
Received 1,732 Likes
Those are the correct part numbers for the front rotors of a RWD IS250 (2014-2015).
If lexuspartsnow.com is saying it should be 43512-30310, those are the front rotors for an AWD IS250 (2014-2015).
ayotomy (12-19-18)
ayotomy (12-19-18)
Time for a new dealer!!
You could argue that 43512-30310 will physically fit, but the reason why it's only one part number for that rotor is because it's not directional.
The part numbers you quoted originally are left and right because the cooling fins inside the rotor are directional...so make sure you put the left on the left and vice versa.
Nowhere in the Toyota parts catalog does it say they are interchangeable...but if it came down to you needing 2 rotors and that's all they had, you could use the 30310.
If the parts guy explained the difference to you, then I can appreciate that...at least then the decision is yours on what to buy.
ayotomy (12-19-18)
https://www.ebay.com/itm/LEXUS-OEM-F...S!-1:rk:2:pf:0
Service rep: https://imgur.com/a/xtz2WnE
Thanks again for everything
I e-mailed the service rep to double check and he said 43512-30310 were correct. I have to reorder this now...waste of my time..smh
And you think the second answer is the correct one.
And btw...the eBay link you posted has the correct rotors in the pic, but not the right pads. The pads are for a 200t/300/350...the rotors are for your car.
The 200t has completely different brakes in the front than the 250...like completely different...they have the same brakes as the 300 and 350.
Good luck with whatever you are ordering...you had the right numbers to start with, you shouldn't have doubted yourself.
Peace...out
ayotomy (12-19-18)
Okay...so if I understand correctly, you asked the dealer the same question twice and they gave you 2 different answers??
Peace...out
Peace...out
I found the same seller with L&R rotors. I probably shouldn't have doubted myself. Just wanted to be sure.
