Recently lowered with alignment
Old 09-25-18, 05:40 PM
gmak
gmak's Avatar
Default Recently lowered with alignment
Long time lurker first time posting. Lot of good info on here.
I recently installed some bc racing coilovers on my 09 is250. Lowered about 2.5”. From ground to fender is 25”. I let the suspension settle for two weeks then took the car in for a alignment today. Doesn’t look like very much changed..can you guys please take a look at the alignment numbers and see if anything stands out.
Also, any recommendations on other parts i may need to complete this lowering upgrade. Thanks ahead
Old 09-25-18, 05:48 PM
gmak
gmak's Avatar
alignment
Old 09-26-18, 11:22 AM
Gville350
Gville350's Avatar
They did you right by putting the front toe to ZERO. But the only thing you can do in addition to what you've done already to get the camber corrected is purchasing and installing camber arms for the rear and adjustable upper control arms in the front. But in my opinion, those camber #s are not worth the expense of such extra parts.
Old 09-26-18, 09:10 PM
gmak
gmak's Avatar
thank you for the feedback
Old 10-29-18, 06:03 PM
2013FSport
2013FSport's Avatar
Received 1,475 Likes on 1,230 Posts
Agree ^^ X2....
Just monitor wear. Adjust pressure to optimize and if wearing on the insides, toe it in a bit or replace the LCA with RCF parts. Assuming AWD is the same???
Old 10-31-18, 07:22 PM
2013FSport
2013FSport's Avatar
Originally Posted by gmak
alignment
fwiw - I'm guessing the alignment dude toed the rear *in* (1/8) to offset the negative camber. That is excessive and I missed it on the first round.
That said if you find the tail end darting around over bumps and when the traction is compromised you might back that off 1/2 that amount or shoot for zero.
I ran -2.1ฐ and zero toe on another car and got good mileage out of them! At the right pressure you could see both inner wear and feathering on the outside. Keep on eye on it!
OneFastF
IS F (2008-2014)
15
06-27-18 09:05 PM
Lexus777
Pacific
07-23-12 05:04 AM
qgoat
Suspension and Brakes
03-18-10 04:19 PM
blueridge
RX - 1st Gen (1999-2003)
08-27-09 01:52 PM
bishop977
Maintenance
06-15-04 10:16 AM
Quick Reply: Recently lowered with alignment
