Ls400 or ls430 calipers on gs300
Old 09-05-18, 03:54 PM
Galikgun45
Galikgun45's Avatar
Default Ls400 or ls430 calipers on gs300
Ever since I went to the junk yard to look for sum ls400 calipers because I heard is a good brake upgrade but wasn' able to find any instead I came across a ls430 that had way bigger breaks then what I was looking for and have found sum forums that talk about it but not give a straight answer into what I need I also want to do the back breaks if possible the ls430 calipers look massive both front and rear and was wondering if it was plug and play or if not what' all I need for this convertion thanks everyone
Old 09-06-18, 06:24 AM
captainva
captainva's Avatar
The LS430 calipers don't bolt up and there is no one online that sells brackets for them that I am aware of. You would need to have something custom made
Old 09-15-18, 05:29 PM
jeffy
jeffy's Avatar
i thought there was one setup floating around with them giant monoblocks (might have even been the ls460) that was from japan? cant verify completely just yet, but im pretty sure it was in one of the ls400 conversion threads.
Old 09-17-18, 10:46 AM
captainva
captainva's Avatar
I'm not saying that it hasn't been done. Just that no one sells an off the shelf bracket to do it
Old 09-17-18, 07:02 PM
Zoolander
Zoolander's Avatar
Ebay has LS400 calipers, that's your best bet.
Old 09-19-18, 11:17 PM
jeffy
jeffy's Avatar
no im not saying just made it work but that there was a japan only aftermarket bracket that worked. i think it may have been several years back and people looked and went through hell trying to find it or a way to get it here in the states though.
Old 09-20-18, 08:17 PM
firelizard
firelizard's Avatar
A company called DSR sold a big brake kit for this car that was actually LS430 calipers with custom brackets.
https://www.clublexus.com/forums/sus...ig-brakes.html
Old 10-19-18, 07:39 AM
hermzxd45
hermzxd45's Avatar
Default Ls400 brake lines
hey y’all I’m doing a ls400 brake caliper swap. Which brake lines are you guys using for the swap. I thought the GS lines will fit but they don’t. I want to go stainless steel. You guys got any good recommendations on which ones I should get. Thanks
Old 10-19-18, 08:44 AM
captainva
captainva's Avatar
What do you mean you couldn't use the GS lines? They stock GS front lines should bolt right up. If you want to upgrade to stainless the stoptech stainless lines for our cars on rockauto are cheap and I've had no problems with them in 2.5 years. Although make sure you check that they're not rubbing on anything after you install or they could get a hole in the line.
jwynn
05-17-16 02:34 PM
pinnell27
08-31-13 05:04 PM
richonenz
04-05-07 03:21 PM
vietnamese
04-25-06 04:15 PM
W Lee
08-25-04 11:17 PM
Quick Reply: Ls400 or ls430 calipers on gs300
