On the littlest bumps, my SC sounds like the whole care is gonna break.
Old 06-15-18, 12:06 PM
Luxurious
Luxurious's Avatar
Default On the littlest bumps, my SC sounds like the whole care is gonna break.
it's a 1993 sc with tein coilers dropped about and inch and a half. on the smallest bumps, it sounds like the whole front end is gonna just detach from the car lol.
my driver side sway bar end link has to be changed, its rattling and just old as hell which I'm getting changed.
even before that, the car just doesn't feel solid.
anything I can do to change or replace? thought about getting sway bars but idk if that'll make a difference.
Old 06-17-18, 02:04 PM
97-SC300
97-SC300's Avatar
Checking the sway bar bushings and control arm bushings would be a good place to start. Do your coilovers use the OEM strut mounts or do they have their own solid mounts? Solid mounts will make the ride harsher obviously. If you retained the oem mounts, check to make sure they are not trashed.
Old 06-17-18, 09:56 PM
shajbot
shajbot's Avatar
An inch and a half? Do yourself a favor get rid of those coils and get some OEM shocks and lowering springs and new control arms. New nice bushings will make your car drive like a brand new Lex plus the lowered height will make it look hot af.
Old 06-17-18, 11:13 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
I'm thinking control arms are shot, maybe play in the ball joints.
Old 07-11-18, 12:51 AM
Tempock
Tempock's Avatar
How do decent coilovers like BC racing compare to a lowering spring setup and OEM shocks? I'm trying to lower my SC and stiffen up the ride preferably for under 1k.
Old 07-13-18, 06:57 AM
FatBrian81
FatBrian81's Avatar
Lowering springs aren't adjustable like coilovers, they go down as far as they go and that's it. With 1k dollars you can do a gixxer_drew setup which will get you the adjustability of coilovers but most guys say it rides better than true coils. There are several write ups here about how to do it along with Drew's original post on Supraforums.
Old 08-02-18, 07:21 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
TBH once I dropped my SC on coilovers it felt like the entire thing was going to break in half.
It also had to do with the steering rack bushing being shot as well as both control arms.
kikcaffine
Suspension and Brakes
24
04-10-18 11:39 AM
luda42688
01-18-16 05:39 AM
lexusben
12-12-12 01:39 PM
LexXxuS101
11-19-12 11:00 AM
jallerd
GS - 1st Gen (1993-1997)
05-26-09 10:13 AM
Quick Reply: On the littlest bumps, my SC sounds like the whole care is gonna break.
