megan racing rear lower control arm install questions - ClubLexus - Lexus Forum Discussion
Go Back  ClubLexus - Lexus Forum Discussion > Lexus Model Forums > SC Models > SC- 1st Gen (1992-2000) > Suspension and Brakes
megan racing rear lower control arm install questions >
Old 05-16-18, 06:44 PM
streetlthl
Default megan racing rear lower control arm install questions
I own a white sc300 its a 1993 and it has been converted to a manual transmission and i love it ive owned it since 2015. so my issue with the car was swaying all over the road allmost *** end hopping around if you hit uneven pavement with your foot on the gas. it has allways done this since i owned it but progressively got worse over time with hard driving i slide the car regularly. i was told it was the balljoints being shot in the rear lower control arms. ouchies very expensive from lexus... so i bought the megan racing rear lower camber control arms for my car they look so sick. i then had to drive the car from Florida to Pennsylvania for a emergency. WITHOUT INSTALLING THE ARMS. it allmost killed me like 7 times. but i made it and lucky for me the place i am staying has a garage and tools and i brought the arms. im not looking to camber the car i just want it not to sway can i install these things without other parts and just set the ajustments to stockish settings? also realistically should i be replacing any other stuff back there just cause its apart... the locator arms dont seem to have to much to go wrong with. the tow arm looks like it has a ball joint does that fail also? any advice or suggestions thanks again
streetlthl is offline
Old 05-17-18, 04:35 PM
Blkexcoupe
Blkexcoupe's Avatar
At this age, almost all the bushings or ball joints will have minor play on our cars. While replacing the LCA, I would inspect all the bushings and ball joints for obvious damage. If you have the tools, then replace the bushings too. I would also recommend loosening and torquing all the oem bolts back to spec to "reset" everything. Make sure to get a good alignment. Don't try to eyeball it and hope for the best.
Blkexcoupe is offline
Old 05-17-18, 09:45 PM
RXRodger
Based on how you are describing what the car is doing, I would say it is more likely the toe arms are the problem. Almost always is. Get a set of those, you can buy the aftermarket ones for $100/ea roughly. Put them on, you will be ok until you can get the other bushings etc replaced. But, if you have the time and money, go thru all of them.
RXRodger is offline
Old 05-18-18, 03:43 AM
streetlthl
Thanks for the input guys yeah I'm probably going to order the toe arms from megan too. I will post pics of the megan components installed.
Old 05-21-18, 09:50 PM
CarelessKp
Post
let me know how this goes suffering from the same conditions.
CarelessKp is offline
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
