Roll call: Spring Rates
Hello everyone,
I am getting back into a Lexus 2is and would like to see what spring rate everyone is running on their coils. Looking for the low IS's. I think this thread will help a lot of people when deciding on coilover spring rate.
Coilover:
Spring rate (F/R):
Picture of your setup:
Do you rub often (y/n):
Coilover:
Spring rate (F/R):
Coilover: BC Racing
Spring rate (F/R): 12k / 8k
Picture of your setup: https://www.clublexus.com/forums/is-...hotoshoot.html
Do you rub often (y/n): Only on bad bumps or bad potholes, AND I HAVE REMOVED THE FENDER LINERS.
I had 12/10 swift no problems. my first set was 10/8 and 10 in the front is to soft if u like to be low. It rubbed often. If u like to drive lower than the top of the tire even with the fender I would even go 14/10 and you'll definitely need the fender mod. The Megan's lp I think come 12/8 but I liked my BC.
steveski
01-10-08 07:48 AM
