GS300 rear toe in
Old 01-06-16, 10:05 AM
blantto
blantto's Avatar
Default GS300 rear toe in
Hello all I am new here hoping someone can help me to fix the alignment problems with my 02 GS300. It has 95000 on it and has no accident history. It pulls to the left currently. I put new OEM caster arms on the front as well as new OEM struts all around. I have had it aligned 3 times and it never has felt right. Can someone look at my most recent alignment printout and give me a clue how to fix this?
Old 01-06-16, 10:48 AM
goodyonsen
goodyonsen's Avatar
I would suggest getting aftermarket toe links so that your alignment shop can adjust the toe.
http://shopfigs.com/v1/index.php?rou...&product_id=63
Old 01-06-16, 05:05 PM
blantto
blantto's Avatar
Thank you Goodyonson, I was thinking the same thing.
Old 01-06-16, 07:17 PM
baconcake
baconcake's Avatar
Also, I notice that your left rear camber is .3 more than your right. If you can't get the left side any more positive, then add more negative to the right side to get the same -1.1 camber on both sides. This will help will pulling to the left.
lexusben
Suspension and Brakes
08-22-13 07:05 AM
qgoat
03-18-10 04:19 PM
vwynn
06-05-09 05:03 PM
mad_trbo
GS - 1st Gen (1993-1997)
06-05-09 03:52 PM
bishop977
Maintenance
06-15-04 10:16 AM
Quick Reply: GS300 rear toe in
