Tire Wear with RSR Downs / Super Downs
Trying to get a gauge on how bad your tire wear is with these springs. More than likely, I'd run these with the stock F sport rims and tires. Does your tire wear evenly?
What were your alignment specs like and how long did you wait after installation to get your alignment done? |
Also interested....
Originally Posted by i2fat
(Post 8924144)
Did you get spacers? He recommended me 15mm on the front and 20mm on the rear.
Originally Posted by nick0327
(Post 8925765)
I just got mine done today (RSR Downs). I am also planning on keeping the stock tire and rims (18") on. I haven't driven with this set up long enough yet so I can't tell you if there are tire wear. But from my research on the threads about RSR Downs is that they don't give you trouble in terms of tire wear (even with 19"). I'll let you know once I have some mileage on it. If you are interested I got mine installed at 168 Motoring. Ask for Kevin. I plan on giving it about 3-4 weeks before I return there for my tire alignment. Hope this helps.:woot:
Originally Posted by Glock47
(Post 8925822)
(Post 8925765)
That's what my setup will most likely be. RSR Downs with 25mm fronts and 20mm rears. I think 15mm fronts would be way too conservative. Hoping that the 25mm aren't TOO aggressive though lol. |
A couple of members have 25mm in the front and rub on dips I believe. Most people have 20mm all around. He recommended 15mm in case it rubs. Haven't heard complaints about 20mm rubbing.
Op, spacers might the wheels look more flush. If you noticed, factory wheels sit fairly deep in the wheel wells. Spacers makes it look cleaner. Some say it enchantes handling as well but it would probably be minimal.
(Post 8926053)
Thanks for the info.
(Post 8926464)
Op, spacers might the wheels look more flush. If you noticed, factory wheels sit fairly deep in the wheel wells. Spacers makes it look cleaner. Some say it enchantes handling as well but it would probably be minimal. |
(Post 8924144)
Originally Posted by Matt3is
(Post 8931052)
I have the rsr super downs and the rear camber wasn't too bad. They are 1.7 & other wheel is 2.2. I I waited a day to get my alignment, around 50 miles to fix my toe. I plan to get them rechecked after a solid month. Hope that helps!
Bump. Trying to decide if I should get a camber kit or not with the super downs
