long tie rods for drifting
Old 12-16-14, 02:02 PM
scott101
scott101's Avatar
Default long tie rods for drifting
hello
I have modified knuckles and extended lca's (wide track). however, this has created the need for longer tie rods (about 2-3" per side). does anyone know of a tie rod from another lexus or toyota or any other car that bolts right in and it about 3" longer than the sc tie rod? it would be a great help if such a thing existed because it would save me a lot more cutting and welding work. I would go with an aftermarket setup like battleversion but I dont think that will give me the extra width I need
thanks
Old 12-16-14, 08:40 PM
k7q
k7q's Avatar
what outer tie rods are you running?
95-00 lexus LS400 RIGHT inner tie rod is about 1" maybe 1.5" max longer then the SC.
Old 12-16-14, 10:06 PM
scott101
scott101's Avatar
stock sc inner and outer right now. car is still in build phase, but i need about 3" extra width on each side
maybe i could try to get two right (passenger side?) side ls400 tie rods and some adjustable rod ends
how much extra width can people safely get out of adjusable rod ends?
thanks for the help
Old 12-17-14, 01:11 PM
k7q
k7q's Avatar
With LS400 passenger side inner tie rods and battle version outer. I think you will have a good amount of adjustment.
You can use LS400 passenger inner tie rods on both sides of the SC.
Old 12-17-14, 01:34 PM
k7q
k7q's Avatar
Pictures of the set up? I would like to admire it!
Old 01-21-15, 12:31 PM
k7q
k7q's Avatar
Ever find the tie rod? I found a longer tie rod, maybe too long.
nguyengs42
03-02-10 02:25 PM
insidejob
01-16-08 08:34 PM
jjbravo
03-16-06 01:48 PM
Quick Reply: long tie rods for drifting
