Steering Rack with Quicker Ratio Available?
Without some hefty modification, I doubt it. The only easy change I know of would be to swap out the power steering ECU with one from a sport design GS300 or one from a GS430. I believe these both will give a slightly (and I do mean slightly) modified steering response (correct me if I'm wrong guys).
Yeah. The ECU will just change the weight. I wonder if a supra rack would be do-able. That's has got to be more aggressive rate, and close to the width of our GS. I guess with custom length tie rods you should be able to make it work, but it would be tough with just buying one and trying it out.
The supra rack is a good bit different although visually they kinda look similar, the supra rack is infront of the engine xmember not behind like the GS, the steering shaft input section is gonna give the problem in fitment, although of course anything could be made to work with a enough determination.
The SD ECU swap can make some difference in how the steering feels but not how it works. It's really just fish oil and although can be felt, if performance is the goal the car is better off just ditching the ECU control and solenoid in the line all together. (in which if your seriously doing steering mods and rack swaps you'd be rerouting/replacing the lines and adding a ps cooler anyway)
Swapping racks could gain you less lock to lock say 3.5 turns vs 4. Which is different than getting more angle from it, it would make the car feel a bit more nible although you still got 4000lbs to maneuver behind it.
Are you looking specifically for more total angle, quicker turning vs steeering wheel input, or better feeling steering?
Do keep in mind one of the biggest reasons the GS steering feels so 'Lazy' is because of the amount of caster designed into the knuckle position, it was done intentionally since the car was more or less designed for old people and old people don't generally dart these big body cars around like people are doing with them 17 years later since the cars have become basically free. It makes the car very disconnected feeling going into turns without much feedback but increases straight line stability especially at high speed. If you straightened up the caster some you would notice a great increase in the steering response.
Ikeya Formula makes lower tension arms that are caster adjustable, but they do cost almost a grand.
A 'little bit' of extra angle is pretty easy to get with the typical spacer on the inner rod to allow it pull into the rack further before hitting the stop.
