1997+ Supra Sub frame Mounts
I searched the forums, but I can't seem to find the answer. The sub frame mounts listed in the DIY for a Supra Sway Bar swap are for the 93-96 TT, but the 97+ part is cheaper. I can't seem to see differences between the two. I know the thickness of the sway bars are smaller on the 97+, but that shouldn't matter for the sub frame mount, right?
All aftermarket sub frame mounts are listed as 93-98, so the mounting holes should be the same. Can anyone confirm? |
You are correct, the mounts have the same mounting points. The cost difference I can't explain though.
source: just swapped my subframe for a 6 speed subframe |
Thanks.
If anyone knows for a fact the 97+ cannot be used, please speak up (or type up). |
Anyone else that can either confirm or deny?
If anyone cares, the 97+ Sub Frames mounts and the Supra TT rear sway bar are already on my car. The mounting holes for the sway bar mounts are a little closer together due to the smaller diameter (20 mm) rear sway for the 97+, but are still usable for the older 22 mm sway bar mounts.
Mods, can the sticky with the part numbers be updated to save members a few bucks? |
pics! do you still have stock dual exhaust?
Originally Posted by Albatross
(Post 8651883)
| All times are GMT -7. The time now is 12:27 AM. |
