Replace OEM brake pads with new rotors??
I am planning on replacing stock rotors with slotted/drilled rotors. Is it necessary to replace the stock brake pads? What are the pros and cons? Thanks.
depend on if your pads are still new or not, if they are pretty new, then keep them. If they are more than half way gone, then replace them, so you don't have to do this any again any time soon.
Actually it depends on what you do with the car. If you track the car than NEVER change the pads and rotors at the same time as it promotes glazing. break in each seperately. For street use you can change both at same time if you want. Doesn't really matter. Since I'm hard on brakes I always change pads and rotors seperately.
hlthlnk
09-07-10 07:41 AM
