Lowering with coilovers
Old 12-12-13, 11:19 AM
Bradwillia
Bradwillia's Avatar
Default Lowering with coilovers
Hi guys. Looking to get some coilovers for the car. however, I only want to do a modest drop. 1 inch to an inch and a half tops. Can I do this with the coilovers? Thanks
Old 12-12-13, 11:57 AM
TigerBrand
TigerBrand's Avatar
Yes you can. However, you can achieve the same drop with coil springs alone for much less. You can probably purchase a spring and shock combo cheaper than a set of decent coilovers.
Old 12-12-13, 12:00 PM
GSteg
GSteg's Avatar
It depends on the coilover. Some will be lower than stock even if you set the height to max.
Old 12-12-13, 12:04 PM
monkey92
monkey92's Avatar
you can drop alot more than an inch and a half with coilovervs, but like tigerbrand said above, you can achieve your desired drop with some spring, but if you really want coils i think the cheapest for our cars might be the megans if im not mistaken
Old 12-12-13, 12:17 PM
Bradwillia
Bradwillia's Avatar
Thanks, sounds like springs then. I like the idea of coilovers so I can raise it back up for the winter. But like I said I think an inch and a half is plenty.
japoneez
07-09-13 02:01 AM
5LtrEater
Suspension and Brakes
05-13-13 06:36 PM
rayy117
IS - 1st Gen (2001-2005)
12-12-10 12:26 AM
kevin.tran
11-08-09 12:52 PM
Lexi D
20
09-16-09 12:17 PM
Quick Reply: Lowering with coilovers
