Flush Spacers on Fsport Rims
#331
Former Sponsor
I originally went with 25mm all around and was rubbing on big dips, I now have 20mm all around and have no rubbing issues on big dips with 3 people in the car and trunk full of stuff.
25mm spacer, factory F-sport suspension and wheels
20mm spacer, factory F-sport suspension and wheels
#333
My 20s --no rub either on factory F Sports with bulky Firehawk Indy 500 tires. lowered too.
#334
Former Sponsor
I have Eibach Pro Spacers 20" that I took off immediately after installing on my OEM FSport Wheels. For sale if any ones interested at 20% off.
#335
#336
FOR SALE 2 Brand new pairs of BLOX Sports spacers never used before
2X 15mm
2X 20mm
centerbore: 60.1
bolt pattern: 5x114.3
Forged Aluminum Alloy Billet 6061-T6
Anodized black
10.9 grade rating bolts/studs
8 grade rating lugnuts
Fits 14-17 IS250/350
PM if interested toronto/gta area
2X 15mm
2X 20mm
centerbore: 60.1
Anodized black
https://www.ebay.com/itm/2X-15MM-2X-...0/162231764854
#337
20 in front 15 in back
so from what ive seen, 20mm in the front and 15mm in the back is pretty good on stocks. what if i bought aftermarket wheels? would i rub? have to get new spacers?
#338
Received 1,732 Likes
If you get aftermarket wheels then there is your chance to get an offset that will produce the same result as the stock wheels with spacers...but without the need for spacers now.
The wheel thread has a ton of photo and fitment information for when you're ready to get new wheels: https://www.clublexus.com/forums/is-...exclusive.html
#339
As for aftermarket wheels, it depends if you keep the width the same as the OEM wheel (front is 8inches wide / rear 8.5inches) and the offsets (which I forgot for OEM)
#340
Welcome to the forum!
#343
#344
I have the luxury wheels which are same spec as F sport (offset too). on RSR down, 25mm front / 20mm back. no rub on rough driving post alignment
Attachment 486664
Attachment 486665
Attachment 486666
Attachment 486664
Attachment 486665
Attachment 486666
Napalvr (06-10-21)
