Flush Spacers on Fsport Rims
#271
I am assuming this is a RWD, would this spacer set up be recommended for AWD IS350 F Sport, or would 20MM or 25MM square set up be best? But absoluetly love the look of this right now!
#272
2017 is350 rs-r down with 25/20 wheel spacer
I received my “down” springs yesterday night !! Today I installed them took me about 2hrs . I love how my ride looks now ! Hella flame! Yeee ..
#273
Hey guys, new to all this and trying to follow this extremely long thread is a bit difficult. So far, I'm getting that the 2 top brands for spacers that don't cause vibration are Eibach and H & R, but when I go to their website I can't find for my car 2014 AWD IS350 F Sport. I only seem to find options for RWD. I have the F sport stock rims and stock suspension, and from this thread I'm noticing that 20mm all around doesn't rub. Can anyone that has an AWD let me know how you found your spacers? Thanks guys
Leo7 (08-16-21)
#274
There's little risk of vibration so long as there's no debris between the rotor and spacer and on the wheel. the spacer itself is machined so its going to be flat. surface preparation (cleaning/sanding) is more important to avoid vibration, more so than brand. also make sure (they all do)they have strong grade 8 bolts.
Massi9 (06-15-18)
#276
Former Sponsor
I put together a wheel clearance calculator in excel and based on fitments I have compared there is approx 1" (25mm) in the front and just under .9" (22mm) in the rear to fender. I have not tested this yet but the more fitments I test from members, the more it confirms my findings.
#277
20mm spacer in the back. This all the way down with the stock tires. *for testing purposes
It will ultimately make contact with area where the bumper meets the rear arch.
If you have tires with a lesser sidewall thickness it will clear.
If your springs are too low or too soft it will rub there under the right conditions.
20mm spacer
20mm spacer
Oneops (02-12-24)
Leo7 (08-16-21)
#280
Former Sponsor
I'm thinking the reason some are rubbing on 25mm/20mm spacers is due to tire size rubbing. It's probably best to go with a size narrower than the oem tire. Some people here may even be a size wider. This thread would be improved if everyone posted their tire sizes too.
#282
20mm all the way around will look nice and not rub. I'm only half lowered.
Also update: new Meyle rotors. replaced those noisy drilled/slotted stoptech rotors. god the new rotors feel like glass. had a nice coating on them too. Go Meyle! Combined with brand new German Pads (stock)
I gave everything a good clean, sand, lube between shim plates and pad "ears" where they contact the caliper block. Calipers torqued to spec. Everything is perfect. I think these Meyle rotors are new on the market cause I've never seen them before. But from past experience, Meyle is a good aftermarket company. Brand new front set for less than the price of one genuine rotor.
#283
My fronts could go "out" maybe 3 or maybe even 5 more mm, but it's acceptable.
Oneops (02-12-24)
