What's a good alignment spec for DD?
I'm getting my alignment tomorrow and for the fronts I'm going 0' but I'm not sure about the rear.. Any inputs? this is just for daily driving and I'm on f-sport springs btw. Thanks.
camber i believe cannot be adjusted
yup, phresh is correct, camber cannot be adjusted unless you get a camber kit. if you lowered your car, the front and rear will be negative. depending on how much, i think 1 inch lowered will give you out of factory spec for your fronts, while the rear is still within factory specs.
camber can not be adjusted but toe can which will help with tire wear.
Originally Posted by IXI187IXI
(Post 6487011)
I know the camber can't be adjusted.. I'm talking about toes. I'm probably gonna go 0's on the fronts and .1 on the rear.
Just got back from getting my car aligned. My SAI and Included Angle is out of spec.. is that bad?
Is weird that my sai and included angle is out of spec cause last month when I got my alignment checked it was within spec. The only thing I changed was putting 4 set of new tires(hankook)
Just got my alignment done, i still feel it pulls to the right a little
http://i59.photobucket.com/albums/g3...e/9599e60d.jpg |
I wouldn't sweat it. The primary numbers all look good.
My sai is so off.. fl-5.8/fr-14.0. Spec range 9.9-11.4.
| All times are GMT -7. The time now is 02:35 AM. |
