Front swaybar endlinks cause pop?
Old 04-08-11, 10:33 AM
kikcaffine
kikcaffine's Avatar
Default Front swaybar endlinks cause pop?
The damnedest thing happened, I noticed my front end link for my sway bar was about to unscrew itself all the way from the LCA, so I tightened to down, and now the car makes a popping sound like non damn stop when going over bumps or when the suspension compresses from the front of the car. I saw the thread about re-torquing the sub frame to 90ftlbs but that didn't make a difference on it. Do the end links wear out and cause this, or would worn sway bar bushings cause this?
Checked:
Ball joints - good
Tie Rods- good/replaced 1 with new unit
LCA Bushings- good
Old 04-08-11, 11:29 AM
MidloSC
MidloSC's Avatar
Strut mounts will do that also. Sway bar and end links are more of a clink, not a pop.
Old 04-08-11, 11:57 AM
kikcaffine
kikcaffine's Avatar
Ok cool, thanks!
I guess they just deteriorate? Can you visually look at them and see if they are bad?
Old 04-08-11, 05:19 PM
xspsi6
xspsi6's Avatar
Strut mounts will do that however scx00 does not have struts they have shocks which just have a little rubber bushing that very rarely goes bad.
Old 04-08-11, 06:34 PM
GSteg
GSteg's Avatar
disconnect one side of the sway and see if you still get a popping noise. If you do, then the problem is somewhere else.
Old 04-28-11, 07:36 PM
SupraTico
SupraTico's Avatar
I'd put money it's your lower control arms (the ball joints.. one side or both)
Careful, cause they WILL pop out when they get bad enough and your whole wheel WILL turn up (like the DeLorean in Back to the Future, but facing up lol) AMHIK...
Old 05-02-11, 06:29 AM
INTIMAZY
INTIMAZY's Avatar
Do you have aftermarket sway bars? If so, it's more likely that the end links went.
Old 05-02-11, 10:28 AM
alfa spade
alfa spade's Avatar
i got the same issue. i just replaced my fronts with coilovers and the sway bar links are all messed up now cus i got angry at them. now my car makes pop noises all the time. just ordered new sway bar links a couple days ago. will update to see if pop goes away.
Old 05-03-11, 09:26 AM
alfa spade
alfa spade's Avatar
I just recieved my new pair of front end sway bar links. i'll take pics and post once i install and see if the noise disappears. prob will take me a day or two before i do the install. i got daddy duties to handle first.
Old 05-11-11, 10:08 AM
alfa spade
alfa spade's Avatar
Ok so i'm finally going to replace my front sway bar links. i'll be done later today and i'll posts any changes. i got a pair of CTR sway bar links. they seem to be the best available ones. they are the only ones that have a nut on the inside of the bolt so that its easier to take off. The OEM ones you have to use a vise grip plier to hold it on one side especially if its rusted like mine. lol. i guess 16 years of being on the car does that to it. lol.
Old 05-11-11, 05:11 PM
TechGreek
TechGreek's Avatar
You don't have to hold them with a vice. They have a spot for an Allen wrench then use a ratcheting 14/15mm wrench and crank away while holding the wrench.
Sway bar bushings can cause a thud / flutter
Old 05-11-11, 10:00 PM
alfa spade
alfa spade's Avatar
yeah i know but the vise just works so much better. and these suckers are so worn out. lol. and on top of that its easier to use a ratchet and vise vice nonratcheting wrench and holding a tiny allen.
well the end result was a good one. after replacing both sway bar links all the dumb sounds of clunk and clank went away... well in the front only. now i hear some of them in the back. not as bad as the front but still in need of replacing. i went and had some fun with the fam so i wouldn't get in trouble for spending all morning at sears looking for new tools and at my car having fun. so i will post pics tomorrow.
alfa spade
alfa spade's Avatar
i just gotta figure out how to post pics first....
Old 05-12-11, 04:08 PM
alfa spade
alfa spade's Avatar
This is the new one and the old one side by side.
Old 05-12-11, 04:10 PM
alfa spade
alfa spade's Avatar
you can tell it was in need of some lovin.
Quick Reply: Front swaybar endlinks cause pop?
