List of wheels that fit TT and LS400 BBK
#93
G37 19 inch sport wheels do not clear the LS400 BBK. they hit by a mm, found this out the hard way yesterday
19x8.5 +43 is the wheel spec for fronts, the spoke hits the caliper ever so slightly. Also, in case anyone ever runs into this, the G37 uses different lug nuts (washer type) than the regular conical ones that we are used to.
just for the record,
Marko
Marko
#95
http://www.supraforums.com/forum/sho...heels-w-rubber
#96
Work has 3 categories
R disk - least amount of lip, but the most brake clearance
A disk - which has the best balance of lip and clears most floating calipers
O disk - maximum amount of lip and might clear floating calipers. o disk is commonly used for the rear rim
#97
Nope, "O disk" is the least bbk friendly work wheel. If you want bbk clearance you're looking for "R disk" wheels.
#100
Confirmed, these will NOT fit Supra calipers or LS Calipers.. There is about 10mm space from the GS caliper to the wheel.
#101
I believe the "Wheel fitment" sticky thread is also a good place to ask about how wheels will fit and whether or not a particular wheel will clear LS400 calipers.
Also, the site below is a good source for which wheels fit and how they look; if the poster lists the BBK they have or pictures are good enough to discern which BBK is being used it may be helpful...
http://rimtuck.com/
http://rimtuck.com/
#103
No, they don't. I've done a little looking and after seeing the LS calipers, these rims and my similar 7 spoke chromes won't fit. If you look at these rims on your car with stock calipers, they are already pretty close, so almost ANYTHING wider than the stock floating caliper (aka, a fixed caliper) won't clear at all.
I'm working on another caliper that could be interchanged on the 2GS/1SC that will let us run Supra rotors with stock wheels. Just need time to get it and fit it.
