ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   SC - 1st Gen (1992-2000) (https://www.clublexus.com/forums/sc-1st-gen-1992-2000-6/)
-   -   End links / stabilizer bar links removal (https://www.clublexus.com/forums/sc-1st-gen-1992-2000/477410-end-links-stabilizer-bar-links-removal.html)
kanukem Jan 24, 2010 06:14 PM
Hey everyone,
Any ideas on how to remove those pesky endlinks? I've read a couple of of posts from people who have cut them off or dremel'ed them off. I've already tried splitting the nuts :(.
For those who aren't acquainted with these, these are the links at the ends of your sway bars that link up to the strut mounts. As most may know, it's a case of engineering with good intentions gone bad. You have to use a 5 mm hex to hold the screw in place while you use a open/box wrench to turn the 14mm nut. The problem here is often times, the nuts are overtorqued or rusted on and in the removal process, the hex seat or the nuts become stripped.
The endlinks are a major source of popping/clunking that you may hear when driving over uneven roads and making turns. So, point of advice for people who have problems with this noise, check your endlinks and have them replaced.
t70 supra Jan 24, 2010 07:28 PM
had to use a plasma cutter to getmine off mapp gas would even work in my 93
tavarish Jan 24, 2010 09:23 PM
If they're far gone, use a vise grip on the boot section and crack the nut with a wrench or ratchet.
kanukem Jan 24, 2010 09:31 PM
i tried the vise grip method inside the boot section but it didn't fit. i'll give it another shot this weekend. it's a pretty tight fit.
thanks for your input guys. Lets keep this rolling!
eemueller Feb 9, 2010 06:28 PM
I just cut mine off using a sawz-all. A little light oil to cool the blade and it took all of 2 minutes to cut off both.
t70 supra Feb 10, 2010 09:56 AM
a cut off wheel will work
Luxor Feb 10, 2010 09:29 PM
I think I used a impact gun to loosen the nuts when I replaced one of my rear endlinks.
TheMole Feb 12, 2010 08:15 AM
All four of my endlinks came off pretty easily. Reason being is that they had a bracket on them that prevented them from turning as the nut is being loosened. I didn't have to use an allen wrench, but I had to on other cars and it was a major pain. Here is a pic of the bracket I am talking about:
http://i172.photobucket.com/albums/w.../SCendlink.jpg
PEARL2 Feb 17, 2010 10:57 AM
since the vice grip and wrench didn't work, use vice grip, heat the nuts up with map torch and then use the wrench
andrewwake Feb 17, 2010 11:16 PM
Let it soak in some pb blaster and give it some elbow grease before resorting to plasma torches and the like.
vinh Feb 17, 2010 11:18 PM
exactly what i did
