FIGS MEGA Arms for the Gen2 GS camber correction
Hello, due to interest I will create a modification to my IS300 arms so that they will work with the Gen2 GS rear lower control arms for infinite camber correction and alignment adjustment. The design change will be a chromoly tubing extension to the rod end mount as rendered below. I should hopefully have some protos built tomorrow but this thread will document the process and updates as well as allow customer feedback so that I can make sure all questions are addressed.
Thanks, Fig
Thanks, Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
I have one guy that will test in TX, so he will get the first set. But the Beta round testing I would like a larger group so I will offer the first units at a significantly lower price.
Fig
Fig
__________________
yes very much so.
__________________
Haha.. That guy that will be the first one to test is Jeff huh??? No love for me Fig? But can you possibly design something into the arms for a greater range of caster adjustment please. I'll be interested in those. Let me know when you're done and I'll pull the trigger.
Caster angle can be adjusted with these and the other Trac links that I am working on so that you can change both legs of the triangle.
Fig
__________________
This is what I finished today. I still need to weld in the eccentric rests, then they will ship out for testing.
Fig
Fig
__________________
