Pic request: 245/35/20 on 20x10s (and camber question)
So my 255/30's are GONE due to camber wear... Anyone have a pic of a 10 inch wheels with a 245/35 on it? (they're alot cheaper)
Also, my camber isn't bad enough to notice by eye, do you think I would need a camber kit to fix this, or should an alignment do? Quincy |
get the camber kit and the alignment having both doesnt hurt. And alot of peoples are running 245.35 on a 10" rim. but the normal sizes for more clearance are 255/30 and 245/35. im runnign a 255/35 i like to have the extra rubber. but i am also runing a slight camber. but try some nankangs or nexen tires those are decently priced and they both run a nice stretch and im running nexens all the way around!
If your camber is barely noticeable by eye yet you are getting severe inner tire wear, I'd definitely get the alignment done to fix your toe setting as it is probably off (Too much toe out) and that is causing your inner tire wear as its literally scrubbing your inner tire away. Toe affects tire wear as much if not more than camber unless your camber is majorly off.
