Price:Lower Ball joint & outer Tie rod ends labor ?
I have read the DIY and will probably do this myself this weekend. But I did call a couple of places that I trust to do work on vehicles. I already have the parts from Sewell and both places quoted me around $275 for labor including an alignment.
From reading the DIY this seems kind of steep for the amount of time involved. Does this seem like a fair price?
If not any recomendations for shops in the Atlanta area?
I just had the ball joints,tie rod ends,caster arms and alignment done friday for $350 including tax.It has made a huge difference.The funny thing is they called me and tried to talk me out of doing it.They said that everything looked fine but i made them do it anyway.Glad i did.
I did it myself last weekend. It took a few hours but not that difficult. I had to stop to go buy a 19mm open end wrench for the tie rod end. I thought my set went up to 19mm but only went up to 17mm. It did tighten up the the front end and smooth it out a bit. My tie rod ends seemed fine but I changed them anyway. The old balljoints had about 1/4" of movement to them. They didnt seem too bad but that was with 71K miles so I can see them getting pretty sloppy after 90k+ miles.
[. I already have the parts from Sewell and both places quoted me around $275 for labor including an alignment.
This is very high quote. I paid $40 for the labor & $120 for both joints.
I don't think car need to be alignment... but anyway this is another 20 bucks.
Where are you located GSteg? I'm assuming you have all the tools & such to perform the job? Send me a PM please, thanks!
Resurrecting this old thread as I recently had this done.
Shop estimated 1hr per side, so 2hrs x shop rate.
You need to go by what your local shop hourly rates are.
Even though it "might" only take 30min for a pro if everything goes well, consider the times when there's a stuck bolt or something that takes a long time to resolve. They can't charge you more if that happens, so that's why they use the standardized "book" rate.
A lot of shops these days seem to have standardize in the internet age and directly follow the "book", BOTH for estimates and also the repair procedures themselves. The last few shops I've been to, they all use repair software such as Alldata rather then making "estimates" based on prior experience.
Therefore to get lower prices you have to either
-find a place that has the lowest shop rate
or
-doesn't use the internet for times or procedures that you trust enough that they will do the job properly but still give you a cheaper price then a shop that blindly follows the instructions.
or
excluesive
Suspension and Brakes
03-31-10 06:47 AM
imjohnphan
12-30-06 04:58 PM
