RCA's and Tein Flex
I'm considering getting the RCA's to correct camber, but from what I understand I would have to raise my coilovers by whatever the thickness of the RCA block. Is there a minimum of the threaded part of the Flex's that needs to remain in the bottom part? I don't want to turn it up too high and it becoming a safety issue.
Thanks in advance for your responses |
Just raise it up to compensate for the thickness of the block. if the block is 1", raise the coilover by 1" to retain the same heigh.
If you have not lowered your FLEX, then you should not worry about it. The rca lowers about an inch, and if you haven't lowered your flex at all, then you shouldn't have that much camber to need the rca's. Try getting an alignment done and see if they can correct it enough to put it back into stoc specifications before you go and get the rca's if you are worried about lowering the car.
Thanks for the responses guys,
My car is lowered and the camber is slightly out of spec. Does anyone know how much of the threaded part of the coilover is supposed to remain in the bottom to not create a safety hazard? I'm sure if you crunk it up to high, you would actually take the coilover apart. Also, do all of you kind of stick with the RCA's from Exact, or is there someone else that has them? |
RCAs are not always an inch think, the RCAs I have are only half inch think.
And yes, someone mention that installing the RCAs and having the coils maxed out made the upper arm hit. However; I can't say that will happend to every GS or that it won't RCAs will lower the car without changing camber and it will lower according to the thickness of the RCA installed. Now, the way to corrrect camber using this methood is by lifting a already lowered car to the previous height before the RCAs were installed. |
I think I'm just not making myself clear, sorry. I know how the RCA's work and the effect they have on camber. If I install a say one inch think RCA and raise my colivers by an inch, do I risk not leaving enough threads in the bottom part of the coilover? How much thread needs to remain in the bottom of the coilover to not create a safety hazard?
Are you serious?
Flex have an adjusment of 3" in order for you to be having camber issues, you have to be about 2+ inches drop, so do the math from there. |
If the coilover body is threaded, it's fine. I've had my coils set on the where the threaded area ends and i've had no problems.
Originally Posted by SloGS400
(Post 3245929)
when you install the 1" RCAs and raise the coilover 1". the height of the car will remaining the same, but less negative camber. |
Originally Posted by dung0981
(Post 3246094)
you can max out the Tein flex but it will not work with 1" RCAs. the upper arm will hit the body
when you install the 1" RCAs and raise the coilover 1". the height of the car will remaining the same, but less negative camber. http://i72.photobucket.com/albums/i1...1282008086.jpg |
Originally Posted by chrispy
(Post 3246097)
Originally Posted by GS FONZy
(Post 3245913)
(Post 3245941)
Are you serious?
Flex have an adjusment of 3" in order for you to be having camber issues, you have to be about 2+ inches drop, so do the math from there. I think you are misunderstanding what he is asking. He is talking about the lower portion of the coilover, not changing where the collars are sitting now. In other words, how far can he unscrew the lower body of the Tein's so he doesn't have to change the settings on the collars/alter where the spring is. Correct me if I'm wrong Slo. Check out this link: http://www.tein.com/tech_info/inst/6y98u.pdf Go to page 5, the measurement you want to check out is the one labeled "B". It is the distance from the top of the shock to the middle (diameter of mounting hole/2)of the mounting point of the lower bracket. By threading the lower bracket up or down this height can be adjusted .98 inches either way. So, in other words, as long as the person who installed it set the coilovers up as tein instructs you to in the directions you should be able to raise the car up to .98 inches with the lower bracket which would account for your RCA's. I think thats the answer you were looking for, hope it helps. |
Originally Posted by macd7919
(Post 3250812)
I think you are misunderstanding what he is asking. He is talking about the lower portion of the coilover, not the part that is threaded with the collars. In other words, how far can he unscrew the lower body of the Tein's so he doesn't have to change the settings on the collars/alter where the spring is. Correct me if I'm wrong Slo.
Btw, if I remember correctly as long as you maintain at least 3-4 full turns of the lower shock body you should be ok. Tein will have the exact info but I believe that is the rule of thumb. Ok, thanks for that info. I just didn't want to raise the coilovers up too much and end up disassembling them by not leaving enough threads in the shock body. I might just get in touch with Tein and find out for sure. Thanks again |
(Post 3250812)
Lifting the coilover an inch will not affect the strut in any way, it might even make the car handle better. |
