Aftermarket springs in front and stocks in back?
When I had my espelir and l-tuned shocks installed the rear sat a little lower than what i like. With a full tank of gas and audio stuff in the back the rear sits lower than the front. I like the look of the rear being slightly higher than the front. Can I use the espelir on the front and use the stock on the back?
You can probably do it. I only say this because the Espelir springs have about the same spring rate as stock springs. It would be a bad idea to have way different spring rates on the car; but in this case, as long as you're not doing any autocrossing, you're okay. This is more for aesthetic reason than performance.
jtgs400
Suspension and Brakes
02-11-09 05:31 PM
