Squeaky noise front right end.
Hey Guys,
I have a squeak noise on my front right end...Had it ever since I got the car. It only makes the noise over the bumps.... I am thining these things: 1. Link Pins. 2. Sway Bar Bushing. I am not able to duplicate the noise when I am stationery. If I push up and down on the car no noises happen...but when i go over things like speed bumps and regular bumps...there is a noise..almost like a loose washer...its a squeaky noise... :-\ Any ideas??? |
Do you have aftermarket bushings?
Even if you don't, it's most likely the sway bar bushings. I have to lube mine really good about once every 6 months...sometimes twice during the wintertime. The squeak is REALLY annoyingly loud during winter if you don't lube it right away. But it's a simple fix. |
Yeah, I think my car does it more when it's cold. what kind of lube do you use?? I know wd40 wud be a bad idea since it eats rubber.... And replacement bushings are probably only 30/40 bucks neway..right??? Do you take them off and lube them...or spray on top and bottom of it? --thanks |
btw they are stockk bushings
Just re-lube them up...I just did mine with some synthetic wheel bearing grease,,,,no more noise.....
