buying 20's need advice weather or not to change brakes
planning on buying some 20's do you think i'll need to upgrade my brakes? i'm still on the stock set...please let me know
If you're doing normal driving then you already have some of the best brakes in the business and there's no need to change. Now if you have an open face rim and want to change it up for cosmetic reasons, then by all means, close the gap and upgrade, it makes a world of difference.
I'm on 20's and stock brakes and they still do the job. However, I have been wanting to upgrade to better pads and/or ss brake lines. I had new pads put on about 6 months ago but I think they used cheaper pads or something because they don't stop as good as they used to with the previous pads. Either way, your good with the stock brakes .
Even though Lexus has great stock brakes you should consider a brake upgrade whenever you go up in wheel size..When you go from a 16 or 17" wheel and you jump up to 20's your stock brakes wont as reliable as they are designed to work with the stock wheels..Now will the stock brakes work?Yes, they will but bigger brakes would be better, IMO..
Neo
Suspension and Brakes
13
05-24-03 11:55 AM
