Rear brake pads from Tirerack
Look like may have gotten the wrong pads. Before I yank off one of the rears to look, can someone tell me if the brake pads on the rear are vastly different looking than the ones on the front axle? I've never seen pads like this before, and have done brake jobs on most my previous cars.
I got a box with these tiny looking, 3 inch by 3 inch things, not a normal looking pad. I'll yank a wheel when I get home, but curiosity is killing me. |
Na man you got the right ones. Take a look at the difference in caliper size from front to back.
Holy crap, those rear pads are are small. I was used to my SC brakes, I guess. Haven't done the front, did the back last night.
The bolts were frozen up on the right side, so changed the pads without taking off the caliper. Bet nobody's done that, eh? Had to carefully use a slim flat metal to slide in (not touching the rotor) and put a clamp on the outside of it, pulling against it with my one hand, and tightened down the calipers with the other. Wondering now if front are dual piston, like my SC had. Will find out tonight. |
Originally Posted by kmaynard
(Post 2813641)
Yeah, I know the front does the work (but thanks anyway), but I've never had a car with such small brake pads in the rear, regardless.
The rotors were slick, didn't find anything dragging my fingernail across both sides. So I didn't see the point. And no vibrations yet. The pads were only about 50% worn, the only reason I changed them was that the idiots at the deale tried doing them with my 30k checkup, said I "really needed new brake pads." Once I got the first set out, I went ahead and changed them, although had I measured first, I would have left them alone for another set of months. |
