19" Axis Malano is rubbing my caliper "please help"
I just got 19 axis malano 8.5 front and 9.5 rear, the front wheels are rubbing on the caliper . What should I do ? Should i get 5MM H&R spacers and longer studs? or shave the caliper?
1. measure distance from inner fenderwall liner to outer most part of tire. If it measures > 5mm, Buy cheap spacers from kragens, otherwise, buy a grinder w/3 grit sandpaper and grind away
This is my first time buying wheels so i dont know what is the offset of these wheels, the front are running 235 35 19 with stocks brake system. Anyways thanks for all input i will get 5mm spacer and longer studs, will not shave the caliper... Thanks
I have a 35 offset and 45 offset Milano 19x8.5 for sale in the classifieds. You will get no rubbing with those offsets. Pm me if interested. I have a seperate set of 35 offsets up from on my car now and I have no rubbing at all.
After all i have to grind the caliper not much just a bit, i spend $3 at lowes and 15 minutes on each side now my wheels are on.
My car have 3 finger front and back with Tanabe springs i don't like at all.
mjr24
Wheels, Tires & Brakes Forum
04-28-04 07:07 PM
