ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   Suspension and Brakes (https://www.clublexus.com/forums/suspension-and-brakes-185/)
-   -   HELP... Tom's Front LCB Rubbing.... (https://www.clublexus.com/forums/suspension-and-brakes/141189-help-toms-front-lcb-rubbing.html)
White98ARISTO Nov 19, 2004 02:56 PM
I just recently purchased the Tom's Front LCB from Carson Toyota and to my surprise when I went to install it today, the bottom bar of the brace hits the tranny. It bolts on, but it rubs the tranny and makes grinding noise when engine is on. I searched CL and all the pics of the brace are not even close to touching the tranny. I already contacted Steve, but I was wondering if any one else has come across the same problem I am having. I hope mine is just a defect. Compared to the stock brace it is lower. The stock brace clears the tranny. Any help was be great. By the way I have a 98 GS4.
Tommy
redgs4 Nov 19, 2004 03:47 PM
I had the same problem. Used some small spacers [washers] to get the clearance - no issues.
I thought I had an old thread on the subject but a quick search did not find it.
White98ARISTO Nov 19, 2004 05:38 PM
Thanks. Will try that out.
Tommy
rominl Nov 23, 2004 11:43 PM
yeah i have read about that before too (other than from red). just some washers and that would do it ;))
Navaz Nov 25, 2004 09:12 AM
I had the same problem with mine, I think it is because the toms parts where originaly designed for the aristo 300V that uses a 4 speed tranny wich probably does not sit as low as our trannys. I just used washers as well and it worked.
ILOVEGIRLS Jan 23, 2005 11:28 PM
how thick is the TOMS lower brace?
kpuri Jan 24, 2005 05:56 PM
Fix for Tom's Front LCB
Tommy
Tommy sorry to hear about your issue with the Tom's LCB.
The good news is there is a simple fix, send me your Tom's LCB and I will send your a new TRD replacement :D
White98ARISTO Jan 24, 2005 06:28 PM
Sure..... ;)
Actually the TRD WON'T fit either.... I just put spacers and its all good now.
Tommy
rominl Jan 24, 2005 09:33 PM
Sure..... ;)
Tommy
nah, just for clarification, the trd fits no problem, and never rub. had that on my car for a long time and all good. never heard about problems from others too
LXOGOOD Jan 24, 2005 09:43 PM
1 Attachment(s)
it's this thick... haha Never got around to measuring but it's a huge difference over stock and a slight difference over the TRD. It's a sold unit and pretty heavy duty. Biggest and badest of them all.
rominl Jan 24, 2005 09:55 PM
ken, question. what are those extra screws for?
redgs4 Jan 25, 2005 12:03 AM
For the swing arms? Or maybe he just through them into the picture to make you guess. :p
morris Jan 25, 2005 05:54 AM
what does the addition of spacers do the the effectiveness, I could see where it might reduce the overall rigidity of the brace since the longer screw space between the brace and the chassis can act as a pivot point if you understand what I mean.
White98ARISTO Jan 25, 2005 08:22 AM
Really? I compared the TRD one to the Tom's one and that top bar was in the same location and it looks like it would rub also, but didn't try to actually put on. My mistake.
Tommy
rominl Jan 25, 2005 09:11 AM
Tommy
well at least i hope it's not rubbing. never heard any noise, and ih ave been under the car couple of times when the car is on the rack. not touching anything at all though
i would imagine it's a veyr tight fit on the tom's just hit i guess?
