popping noise when comming to a stop during braking
I hear a popping noise comming from the front left or front center area under the car 2 out of 5 times during the end of my braking. When i brake normally and slowly come to a complete stop i hear a popping sound right before im going to stop.
I tried to diagnose it further by seeing if it only occured during hard braking, soft braking ect. But it seams to occur 2 out of 5 times during hard or normal braking. its wierd it doesnt happen every time. could my left caliper be messed up?. or perhaps the axles or something. I also hear something loose in the same area sometimes when im driving over bumps. Perhaps that could be whats causing this but i have no clue what it could be. Any insights on this before i get under the car and check things out would be appreciated. BTW i got new brake pads and cross drilled slotted rotors and new tein basic coilovers over the past few months if that means anything.. |
it may be your balljoints or bad bushings.
After driving with this noise for a few week. I noticed that it occurs most after i drive for more than an hour. It will happen 80% of the time at the end of my braking no matter how hard i brake or how soft i brakeThe popping noise sounds like a piece of metal breaking off or popping out of place or something. Usually if i just start the car in the morning and drive around for a half an hour or so i will not hear the noise at all maybe only 20% of the time.
I've when to my mechanic to diagnose the problem and he checked to see if everything was good and stable under the car and he discovered my sway bar endlink on the drivers side where the noise is comming from is no good. It has freeplay and you can wiggle it around. I'm not sure if that will fix my issue as it sound like it may be something else but hopefully thats it. so I'm thinking it has something to do with a part that is affected by heat or continued use(perhaps the caliper?). As it seams to occur more frequently and almost every time when i brake when the car has been on the road for 1-2 hours or more. |
I had the same exact popping noise come from my car ; really only happened when i applyed the brakes.
I replaced the front calipers and noise went away. |
Originally posted by BCSC300 I had the same exact popping noise come from my car ; really only happened when i applyed the brakes. I replaced the front calipers and noise went away. |
Mine was doing the same thing, i just had the whole front chassis tightened , and no more popping noise. try it first its cheap and i bet it will fix your problem.
Originally posted by PROMETHEUS Mine was doing the same thing, i just had the whole front chassis tightened , and no more popping noise. try it first its cheap and i bet it will fix your problem. |
not the suspension the chassis
Originally posted by PROMETHEUS not the suspension the chassis |
the car has to be on the lift, so unless you have one no, and just tell your mechanic to tighten the chassis, if he doesnt know what that means i suggest getting another mechanic
IT's your SHIMS!
Spacing issues between oem brake pads and warped shims caused loose contact with the calipers.. This problem is seen in alot of Toyota and Lexus cars according to my mechanic.
Fix was New SHIMS, SHIM FITTING KIT, AND SLIDE PINS. |
