Front Strut Nut Size?
Hello:
I am in the process of installing my TRD strut tower bar. Does anybody know the size of the nuts? Looks like 16mm, but I can't be sure. Also, anybody have any helpful installation tips? Thanks! Bill Boshnick 99 GS4 56K BBS RX 17's WIN Corp Grille TRD rear spoiler K&N CAI |
size is 14mm make sure you use 6 point deep socket those heads will round real easy
Originally posted by lexforlife size is 14mm make sure you use 6 point deep socket those heads will round real easy |
Thanks for the tip!
Just got my 6pt 14mm deep well socket and it seems to fit like a glove. Haven't done the swap yet. The holes of the bar don't seem to line up with the strut studs (haven't taken the nuts off yet). The TRD installation instructions (in Japanese) said that in this event, to remove the nuts, jack the car up and lower it, and then try again. Since I don't have a floor jack at my disposal, does anybody know an alternative? Thanks Bill Boshnick |
Just took of the nuts without any problem, and of course the STB holes do not line up with the studs. Figures. . . nothing is as easy as it seems.
-Bill Boshnick |
Success!
I jacked up the right side, and with one side of the STB on the left studs, gently shoved the STB on the right side studs. Worked like a charm! Can't wait to give it a road test tomorrow. Thanks! -Bill Boshnick |
Originally posted by Billbosh Success! I jacked up the right side, and with one side of the STB on the left studs, gently shoved the STB on the right side studs. Worked like a charm! Can't wait to give it a road test tomorrow. Thanks! -Bill Boshnick |
